On a 996tt 2004, after a hard run with engine up to temp. where should the fluid level be on the dip stick for Pent 11 fluid level. I did the 10-30 clutch pump and checked the level when cold. Had to remove some fluid for it to read in the "cold" zone, but now with the engine up to temp no fluid shows on the dip stick?
Edited by rmoudry
Top up till the hot full level with the engine in hot condition and keep an eye on the fluid level for a while. Perhaps there were still airbubbles in the circuit, or there is a fluid leak somewhere, outwardly or inwardly (internal leak in one of the pumps or steering rack)
