2004 Cayenne S.My question is: How much transmission oil would be required when changing a valve body? I seem to recall reading that most of the oil would be trapped in the converter & it would only require a couple of liters to refill. Had a valve body replaced & indy charged for 9 liters @ $45/l..Just like to get my facts straight before I write this guy off.. Thanks
If I were doing the job it'd take 9-10 liters. There's no chance I would replace a valve body and not do a full flush and fill.
You didn't get ripped off in my opinion. That said, the fluid was pricey and was likely Porsche fluid.
I think I was probably confusing that job with a filter change where it seems you don't drain all the oil.
Good to know I didn't get ripped off. I feel better now.
Thanks for your input.
FYI for next time.....the OEM Porsche fluid is toyota type 4 fluid.....if you search my name, or in the stickied oil recommendations thread, you will see the oil analysis i did between Porsche and Type 4 Fluid.
At 7 bucks a quart for type 4....you can afford to change the fluid whenever you chose, including valve bodies, or filter changes.
