My 2000 Carrera 2 has the electronic throttle. In order to get access to the throttle body for cleaning, I tried to open the throttle plate by turning the ignition key on and wedging something between the throttle pedal and the seat, as I was working by myself. But the throttle plate opened just a little bit and, in any case, CRC, that makes the throttle body cleaner that I have purchased, recommends not to spray on the system, when the system is energized. Could somebody kindly advise the proper procedure to open the throttle plate?
Thanks, Loren. I was concerned that forcing the throttle plate to open could cause damage to the actuator, but that is not obviously the case.
