I just had Hip Replacement, and need the dimensions of the drivers seat rail so I can have a adaptor plate made to move the seat further back and two inches higher. I need the front bolt size, location and angle, locating Pin and rear bolt location and angle if any. It will be 6 weeks before I can measure my seat rail, but with the info I can have the adaptors made so I can get into my 2001 C4 Cab. Thank you much for taking the time to do this. Or if someone has a drawing of the bottom pan or know where I can download one would also do.
2" higher? Are you going to have them put a bump in the roof too!??!? ;-)
I have a pair of "Seat extenders" that I will sell you for $100. They move the seat mounts back ~2-3". They go under the stock mounts, so you could have spacers made to raise the seat also.
http://extendmyseat.com/porsche-911-1999-2005-996-driver-side-seat-brackets/
MY2001C4 is a ragtop, the added height will help me meet the requirements for Hip replacements precautions, I will look at the web site you provided and will get in touch with you for the extenders you have if I feel I can use them, Will have one of my buds take some measurements using the specifications of those extenders. will contact you next week, Thanks
