Hi All,
Recently purchased a 2002 996 Carrera out of the LA area, 1st Porsche for me. I am in the process of going through some maintenance items on the car. I am going to be performing a brake fluid change out or flush with use of a pressure reservoir and the Durametric software to operate the PSM to bleed this car. Any idea how much brake fluid will be needed for the job i.e. 2 liters or more ?
Brad
With the power bleeder I use I generally burn up almost a litre. I would imagine that 2 litres should be plenty.
Cheers
Just remember that brake fluid is not paint friendly so it's good practice to be tidy and use such things as a fender cover etc
