hi,
im currently changing the gearbox oil on my 1999 C4, so far it has taken 2.8l and nothing has came out the fill hole yet, Car is sitting level. Should I keep filling or stop? 1999 C4 manual
thanks
Listed as 3L capacity. Mine took about 2.75, so it seems to vary.
Fill till it comes out. I dont think there is a risk of overfilling in this case
Uwon, did you ever remove and check the oil level via the plug (non allen head) near the shifter cables?
If so was it near the plug?
I filled mine until it spilled out of the #1 hole on post #61 of your link and that was about 2.75L
2.7L is the correct fill level, you should be fine.
