The engine light is on: code P1126. From other threads I understand that the first step is to clean the MAF.
Does anybody have a procedure for removing the MAF from the engine and cleaning it?
The suspect areas are:
- Incorrect signal from MAF sensor
- Intake air system leaking
- Fuel pressure too low
- Volume supply of fuel pump too low
- Fuel injectors fouled
Thanks, Loren. How can I practically look into the suspect areas that you listed? I have the Durametric tool. For each area, are there parameters that I can read with Durametric and compare with the normal values? Also one possible cause for the P1126 error should be that the oxygen sensor itself is faulty. Is this correct?
