996TT manual transmission and front wheel drive oil replacement...
Very easy task. You first have to jack the car and have it level properly. Tool needed: 10 mm allen wrench for the transmission ports. I got one mount on a socket. 17 mm socket for the front wheel drive transmission. 10mm sockets for the cover plastic nuts Very small and thin common screwdriver for the panel clips. Torque wrench. A pump for the fluid. I use a Motive Power Fi
One comment: On any transmission or axle oil change, you should always remove the fill plug before the drain plug. That way, if you cannot get the fill plug out, you are not faced with an empty trans or drive unit and no way to re-fill them.
