Just got a new enclosed ATC trailer and when hooking it up today for a maiden voyage around the block, the turn signals and brake lights worked fine- got a check trailer lights prompt when I turned on the headlights- and no running lights. I used it to tow a small enclosed trailer last fall and it worked fine. No errors. I have a CS with the factory towing package- May '04 build. Any ideas?? I understand there is a TSB but can't find it on the list.
Thanks as usual. Going to "fiddle" with wiring tomorrow and if that doesn't work then a trip to the dealer... :(
FWIW- disconnected a couple running lights as there were 17 of them! Lights work fine now- probably drawing too much current for the module... the S pulls the 18' enclosed aluminum trailer VERY nicely BTW.
