Dear all
I do have an (electrical??) issue with the "Additional Coolant Pump"
During read out an error is reported. Up to now I do no not know if the pump is defective or the control unit.
To change the pump (of which I do not now if it is defective) you need to lower the engine, and remove:
fuel filter,
secondary air pump,
intake distributor side 1-3,
shut off valve.
A major task which I trie to avoid.
An other approach is to ativate the pump the by appying 12Volt at the DME control unit.
therefore I need the electrical diagrams of the 997 turbo year 2007/2008.
I already tried at the official Porsche side with the PIWIS system but I did not succed.
Is there any one having these diagrams available.
Would be a great help!!
Regards
Hans, The Netherlands
