I bought my cayenne then the multi colors display went bad. Had a day off today so I took it apart to solder and fix to get the display back functioning again but I have another problem arises from this fix was now all the cluster won't light up. Only the dials light up but not the cluster behind. Any one know a fix to this?
Picture say it all
post-92056-0-19743600-1381752373_thumb.j
Ok this might be helpful I back tracked myself. I took the liberty to replace the two orange transformers at one go that maybe the one in charge of lighting up the analog display might not be sitting properly. So I will have to remove the cluster again and get things fix again.
I wasn't sure which one of the transformers to replace so I replaced them both. Will have to go over the details again tomorrow. Could be my crappy soldering skill.
