Airbag Light
If you hear a lot of grinding noise when turning your steering wheel or you hear a grinding and/or squeaking noise from your steering wheel that gets worse over time or if you recently removed your steering wheel, you might get the infamous airbag light !!! AND when you take a Durametric tester and run the codes you get the following: Fault 21, Ignition circuit, driver is pretty common with these symptoms. Its probably time to remove the steering wheel and check your clockspring. The cloc
  • 3 years later...
