I know my car has only one transmission (where gears are) and that requires ATF fluid and to be changed as described on another post I recently wrote about, but where I'm getting a bit confused is on the differentials.
There is a diff in the front axle of my car, but is there a diff in the rear too? Do diffs use a different liquid/fluid/oil than the tranny (+02 cars are very specific with regards to ATF to be used on the Mercedes built boxes). Do I need to change out the fluids in the diffs too if I do the ATF tranny flush/filter replacement? Any DIY on this?
Please forgive my ignorance on the matter :blush:
Edited by GOB
You have separate front and rear differentials in addition to the Tiptronic trans. Because yours is an 02, you have the benefit of both a fill and drain plug on the re diff, something the earlier cars lacked, making fluid changes a bit of a pain. Your rear diff uses and 85W90 hypoid gear oil, while the front diff uses 75W90.
If I can make a suggestion, invest in the Bentley manual for your car, it contains copious information and photos on these service items and could save you a lot of money in the long run, and you can get it at the RennTech store link under the "Special Offers" tab at the top of this page.
GOB, Also there's some very useful information on oil changes, light bulb replacement to be found on this site... go to:
1. DIY Tutorials
2. Carrera 996
3. Then scroll down for specific information.
