CTT 2004 78Kmiles.
car starts up first time..there is no chugging or struggle to start up.
but first thing when cold/over night, the starter still whirrs for about half a second as if still engaged to the crank..
when the engine is warm , there is no issues
could this be a bad return spring or solenoid problem or failing starter or weak battery?
any advice on what action to take please?
( the coolent tubes are aluminium and changed a while back by previous owner)
cheers
My '04 has been doing this for years as well. It doesn't always happen, but is worse in cold weather. 102k miles
porsche / vw / audi starters commonly make a whirling/zinging after run noise..
Like mentioned above they can run like that for years or be replaced for piece of mind or for eliminating the noise.
