"pending" code P0507 (Idle Air Control System RPM hight than expected)
I Should also add that I have a P0441 Code as well.. Not sure if they are related.
P0507 Idle Air Control at Stop - Above Limit
Possible cause of fault:
- Leaks in intake air system
- Leaks in crankcase ventilation
- Throttle adjusting unit faulty
P0441 Fuel tank ventilation system above limit value/below limit value
- Tank vent faulty (remains stuck in an open or closed position)
- Tank vent installed the wrong way round
- Leak in scavenging lines between tank vent and positive crankcase ventilation (in the Turbo via a T-piece also on the intake side of the turbocharger)
- Scavenging lines between tank vent and positive crankcase ventilation trapped or blocked (in the Turbo via a T-piece also on the intake side of the turbocharger)
Yes, they could be related - fix the P0441 first then clear the codes and the P-507 will likely go away.
Also, I removed the duplicate post on this same topic.
Hi Loren, thanks for condensing my post
I've purchased and in the process of replacing the Purge Valve for Fuel Vapor Canister part 948-110-202-01
Since I'm experiencing longer the normal crank time as well as issues not starting up after gas fill, the Purge Valve was suggested to be replaced.
So I guess start there and see if that hopefully resolves the P0507 (it "should" at least take care of P0441)
So I can officially say I replaced the Purge Valve for Fuel Vapor Canister part 948-110-202-01. Total PIA (IMHO) and hope to never have to do that one again.
So when firing up after replacement, got a PSM Failure Workshop message on dash along with the Yellow Hazard Sign with the (!)
Scanned codes, old DTC P0441 showed up (of course) and NEW "pending" DTC P2138
I turned off engine and restarted, PSM error and hazard light went away, rescanned and NO pending Codes now!. Went ahead and cleared the original DTC P0441 and gave it a drive around the city.
so far so good.. Ugh!
FYI - DTC P2138 Throttle/Pedal Position Sensor/Switch "D" / "E" Voltage Correlation
Diagnostic conditions
  • Engine running
  • Short circuit to B+ in wiring harness
  • Short circuit to ground in wiring harness
  • Open circuit in wiring harness
  • Throttle adjusting unit (position sensor 1 or 2) faulty
  • DME control module faulty
NOTE: This fault is always recorded along with another throttle fault.
Edited by srfrdrew
Thanks to Mudman2, Ciaka and Loren for your excellent write up and suggestions!
Cayenne is purring like a pig!
Edited by srfrdrew
