the spoiler was deactivated some time ago due to a permanately mounted spoiler. I had it removed and would like to activate the automatic spoiler.
I checked the fuse and it is good, but the manual switch still does not raise/lower.
Anyone have a schematic/guide so I know where to look and what to look for?
:notworthy:
Will
'00 Boxster owner
Edited by willcapp
Usually when they install a fixed spoiler they disconnect the cable to the spoiler drive motor and remove the spoiler light bulb in the instrument cluster. You should check and see if those have also been put back in place.
I will check the spoiler drive motor. Where is it located?
The spoiler bulb still lights and diappears (as designed).
thanks again,
Will
Remove the luggage compartment lining in the area of the rear panel (4 plastic pegs) and connect the plug connection to the spoiler drive motor.
