I did some testing with fellow forum member and his new 74mm throttle body. His car (same as mine 2000 S) is really quick and accelerates amazingly well! Well I now know what I have been missing with the 74mm. The time in his car really accentuated the throttle response issue that I am having.
In 3 or 4th gear at 3K it seems like it can take up to 3-5seconds to get over 4K! At 4.5K things wake up and seems fine but it is all too late! At 3K, I would look over and say I am “flat” (pedal to the floor board) here… and his reaction would usually be dismay…
Could my used TB be defective? Is there a vario-cam problem? Is there an intake or exhaust acoustic problem?
His car is pretty much stock with the exception of the TB and intake plumbing for it. The plumbing is potentially “smoother”. His engine is better maintained..
Mine is modified much more:
short snorkel
rougher prototype intake tube for the 74mm TB; 3.25” dia. rather than 3”
secondary cat by-pass pipes
stock S by-pass muffler (worse flow?)
softronic tune
leaky spark plug tubes/older plugs
older air filter
5w40 oil….heavier
I am wondering if the stock tune works better with the characteristics of the 74mm TB. Any thoughts?
Edited by jaykay
I recently worked on a 996 with aftermarket air intake pieces. the piece with the MAF mount was reversible and of course was in reverse. Thus making the MAF sensor installed in the wrong direction of airflow. This caused poor performance and an intermittent PSM fault (same fault as brake switch oddly enough.)
