Hi Everyone,
2004 cayenne turbo SCan someone tell me where the brake boost pump relay is,I have no power to the pump,the fuse is ok,.
I have brake boost warning,first checked the pipes for leaks but the pump does not kick in.
Thanks,I have located the relay ,and the relay checks out ok ,just in case I swapped it with another and still no power to pump,connect pins 3&5 together and pump works and the effect is felt on the brake pedal,so I would presume that the pressure sensor in the booster operates the relay for the pump so---How can the pressure sensor be checked and how does one locate it. thanks for reading
