Targa sun shade will not open nor close. It also won't retract all the way. You can hear the motor running fine. When I push sun shade to close I can manually pull it out and it will try and close but then slings right back to open position. Any ideas?
Anyone with 996/997 Targa install sun blind in there cars successfully please help! I hope there is a way to do it without removing the sliding glass. Is there a way to drop down or loosen the plastic railing for sun blind in order to fit the plastic tabs into the aluminum holders?
