This module got wet and starter will not turn over, I soaked it in rice for 24 hours, cleaned it with pcb cleaner reinstalled it, only thing I could not check was the immobilizer, the start relay and DME. wouldn't energize.
Does any one know if it can be checkout/ tested out of the car?
Not easy to test out of the car.
It might be better to get access to Durametric, a Porsche PST2, or Porsche PIWIS tester - one of those may point to where the problem is.
You did check all the fuses? Yes?
