Hi, I am supposed to go to the track this weekend but the CEL came on in my car. It is a 01 Boxster S. The 2 fault codes are P0133 - O2 sensor, and P0507 - Idle control at stop. I also just replaced teh O2 sensor last week. How bad would it be to go to the track with these fault codes? TIA
P0133 is an aging of the oxygen sensor. Sometimes resetting the fault code makes it go away and sometimes yo actually have to replace the sensors.
P0507 is Idle Air Control - Idle Speed Too High. This is usually cause by a sticking idle control valve and/or air intake leaks.
As long as the CEL is not flashing you are okay to drive the car - performance still might be affected though.
