I just replaced the dimmer switch/turn signal switch on my 1987 911. There was one wire that was not connected, it is the gray/black wire to goes from the dimmer switch lever to the headlamp switch. Does anyone know if this wire should be connected and if so where should it be attached? I checked the wiring diagrams and could not find the gray/black wire on the dimmer or the headlamp switch.
Thanks Chris
