My 2003 C2 6 speed coupe is in for service right now for a crunching sound and feel to the clutch pedal. The service department told me that there is no TSB on this, however, I recall that there indeed is a TSB.
Loren, do you have the number or reference for a TSB on that problem?
//// :) \\\\ spider
Spider,
There are two TSB's for clutch issues but they are for much older cars (MY99 and MY00). Your MY03 should already have the new parts.
Can you tell if the sound/feel are at the pedal or in the clutch bell housing?
Apparently the assist spring in the pedal assembly was dry and was binding against something. It was lubricated and now seems to be fine.
Thanks for your help Loren.
//// :) \\\\ spider
