I changed my stock seats with aftermarket track seats and my cruise control stopped working around the same time. Is this a coincidence or does the stock seat replacement have anything to do with the non functioning cruise control? Any help would be appreciated.
Has to be a coincidence, there is nothing in common between the seats and the cruise.
Check fuse B7. Then check the brake and clutch switches. Ideally, you need a Porsche tester of some sort (Durametric, PST2, PIWIS) so you can check the switch signals. There are two sets of contacts in the switches, and although the brake lights might work, the other set of contacts (used for cruise) may not.
