I did a lot of reading and watching of videos on the subject of bleeding brakes. I bought the Motive Power Bleeder and a few liters of OEM brake fluid. I thought I was ready to go but I just read a couple of posts that said that if you have PSM, this isn't a DIY because you need a PTS2.
My car is a 2000 C2 Cab Tiptronic with PSM. Am I screwed?
You only need to bleed the PSM if any of the brake, or PSM lines, or PSM control units were replaced. Or if you are switching to say a purely synthetic brake fluid from the Porsche standard brake fluid.
Durametric will also allow you bleed the PSM on most models.
