Sorry if this isn't the correct place, but I recently got a Airbag Fault Code: Unknown DTC: 28. Does anyone know if this is related to the airbag in the steering wheel and/or the airbag retaining frame? I have a 2000 Boxster 2.7.
Moved to Boxster forum...
Fault codes 12, 13, 28, 29, 40 -- Ignition circuit, driver's side airbag
Possible cause of fault
- Short circuit to B+/grouncl or open circuit in the wiring between the driver's side airbag unit and the airbag triggering unit
- Driver's side airbag faulty
Has the door panel been off for anything recently?
That would make sense. I had the panel off about 2 months ago to replace the window regulator.I guess my next step will be to remove the panel and inspect the connections. Unless you think there are other steps I should take.
Thanks so much for your reply. There isn't any info out there about this error code.
