I have replaced the clutch, pressure plate and release bearing. I have attached the transaxle to the engine and have had difficulty getting the clutch slace cylinder back into the housing. I can't seen to compress the piston enough to get the bolt hole to align. Also, should I be able to press on the release lever through the opening in the housing?The lever does not seem to want to move forward. Any ideas?
