anybody tried to source a replacement gear for the convertible top transmission? its a big white nylon gear that broke on mine. new trnny is 600+ and the fix is easy just need the gear all the others are metal. thanks in advance
Well if no one has tried, I'm going to look around for a gear manufacturer to see what it costs to make a run of say twenty. Since this is really the only wear item in that transmission. Even at 50 bucks it would be a bargain compared to 600 for a new transmission.
Find some who is doing desktop modeling. They should be able to model the gear very easily and many of the units now can use a nylon material. Once a you have the program it can be used by almost any machine.
Thanks for the response. I had also considered that but since mine is damaged won't that be a problem? The model needs to be intact for proper measurements to be input I thought.
