I just got this 996 carrera 4 a few weeks ago and noticed that the display show about 3 segments low. Didn't have
the owner;s manual with me so I assumed (incorrectly) that that meant about 1.5 quarts low, so I added a quart.
Now it shows over full and the dipstick level (I forgot it had a dipstick) shows just above the "bead".
should I drain some out?
I would leave it. you are barely over. In fact, if you follow the directions for checking the oil, get the car to operating temperature, turn it off and wait "a few" minutes and then check, I bet you are not even over on the dipstick.
