Am I missing something again?
There just isn't enough room to pull this **** thing out :S
I'm sure there is a more straightforward way than having to go down the route of removing exhaust components and finding my way to removing that bracket surely?
You know I was thinking how can you get the coil out with the mufflers on, but I have not seen one tutorial saying you need to remove the exhaust to get the coils out.
Ignore, looks like muffler and then bracket out
Take the muffler out WITH the bracket.
3 - 13 mm nuts on the bracket and loosen the sleeve on the cats. Then the muffler will rotate down and out.
Taking the mufflers out will save you time and bruised knuckles.
Was bored so did it again yesterday.
Was actually quite easy, just take the connection off and it just comes right out.
