Hope you guys can help ?
The handbook lists the follwing for 18" Wheels
Front 7.5J x 18 H2 Offset 50 mm
Rear 10J x 18 H2 Offset 65 mm
Almost everywhere I have searched I can not find 18's with 7.5 , they are all 8.0
Is it ok to use 8J x 18 for the front, if so, what is the offset ?
The car has 030 suspension if that makes any difference.
Any help please .........
Mark
The offset on the 8 inch front are still 50 or 52. IF you want a 7.5 inch rim still for the front you will need to find one from an older 996 (try eBay). Also, you can get a new wheel that is 7.5 with a 50ET as long as you are looking for a 986 wheel.
For what it is worth....I have two sets of wheels/tires (one for the track and one for the street) and my fronts on my track wheels are 7.5" Sport Designs with 225-40-18's on them. My streets Have the same 225-40-18 tires but on 8" fronts.
It is no problem to use 8J x 18 for the front with offset 50.
I did that on my '99 C2 by fitting Carrera 18" rims of the '01 MY.  :thumbup:
Thanks to both of you guys for the help
Mark
