I just installed the May of 2013 DVD map update to my PCM2.1 unit. Your Nav unit will require an software update to version "B" if it doesn't already have it as a result of doing the 2009 map update. I know the map update isn't inexpensive, but when you're constantly using your nav unit, it's nice knowing the maps are current within the last few months.
Thanks, didn't realize the new one was out. We have a lot of new roads around here in the last couple of years so I may just go ahead and purchase the newest one again.
Can you share the part number for others?
The new 2013 part number for the upgarde (PCM2.1, DVD navigation) is 997 044 903 51. The package also contains the PCM software updates, in addition to the new map DVD, if your unit requires a software update prior to using the new map update. Installation instructions are not included, but there are some TSBs available on this site that walk you step by step through the update/upgrade process. Just another great reason why it pays to be a supporting member of this site . . . .
Edited by spooltime
