I'm hoping for some help in measuring the height on my PSS9's. The specs say the adjustable range on the front is 85-100 mm for the measurement from the bottom of the spring perch to the center of the mounting bolt. I'm right in that neighborhood, but I"m concerned that the adjusting collars are almost at the bottom of their range and the car is sitting pretty low overall. Seems like the collars should be somewhere closer to the middle. The red lines show the two points I'm measuring between, are these the correct points?
post-90208-0-61654100-1376361306_thumb.j
