I filled my tank to the top, and still my gauge reads a bit past 3/4!!!! Is this common?
I know that with my 944 the gauge never read full. and it was a ground issue. Is this the same?
  • 2 months later...
There are cables inside your gas tank that can become "tangled" in the sending unit and not allow your boxster to indicate the accurate fuel level.
Mine did what yours is doing until my mechanic opened up the gas tank from under the battery area and tied off the cables with a tie wrap.
The dealers replace the sending unit so they can make money - $800 incl. labor and parts if I'm not mistaken.
