Does any one know this fault code, I have looked in the porsche diagnostics, but cant find this code. I can find the 1549, but this is for the parking sensors and this comes up in the Bosch Digital Motor Electronics 7.1.1 module.
P1549:Vehicle electrical system voltage via main relay - No signal/communication, test conditions are not-completed, fault is not currently active and is not causing a DTC light
P1549 Park Assistant Sensor Power Supply
I would reset it it and see if it comes back.
If it does come back check the sensor wiring connector.
If that is good you can test the sensor with a volt meter.
