1997 Boxster, 5 sp, silver, black interior, made in germany.
I need the turn signal mechanism - pushing up to signal a RH turn results in the stock moving a slight amount - blinker does not engage nor does it hold in place.
I want to install floor lights on driver and passenger side. I understand that this feature was optional? In any case, I'd like the p/n for the lamp holder/shell - I am going to install it myself. Since mostly all boxters have these lights, i am not to picky about getting the one for my 97....anything from 1997-2007 or later will probably work.
John
  • 10 months later...
What about flashers, is there a part number for the turn signal flashers?  I am a first timmer here with a 2003  boxster s .  If I have posted n the wrong spot please forgive my ignorance.
Edited by Rumtan
How many stalks do you have on your steering column? 2, 3 or 4?
1. Turn Signal
2. Wipers
3. Cruise Control
4. Onboard Computer (OBC)
Here is a picture of a 3 stalk set-up w/ no OBC
911%20993%20986%20996%20gt2%20gt3%20turb
Edited by kbrandsma
All Boxsters have the door panel lights and there was an option "IXX2 Illuminated footwell, (at least in the Carrera).  Not sure about the Boxster. So unless you have this option you'll have to do a work around.
I added footwell lights on my 986 Boxster over three years ago. It would be an identical installation for you.  It is a very worthwhile mod!  I used super thin LED lights and connected them to the overhead light switch so that they have the same on/off properties as the rest of the interior lights.
Press HERE for the link.
Edited by kbrandsma
