Becker Gummy Knob Fix
Becker radio sticky knob fix. I actually performed this fix on my radio knobs about 3 months ago, but did not want to post anything until I know it is capable of surviving the 90+ heat wave we get here in DC. Well the fix helded up with not degradation in the appearance, texture, and feel so here is what I did. (sorry no pics of the painting) 1. Remove knobs from the radio by pulling the knobs straight out 2. If the knob have been textured from prior attempts to clean the gum
  • 6 years later...
I’ve found that using a method that works for classic muscle car steering wheels, headlight switches, etc. also works for the Becker knobs.
Toss ‘em in the dishwasher. There is a property in most dishwater detergents that gets rid of the sticky surface. If you don’t have a load ready to run and a captive silverware device (small plastic cage for plastic lids, etc.) then you can simply put a few drops of liquid dishwasher detergent (I recently used Cascade) and rub the knobs until you get a black slurry going, rinse and repeat as necessary. Generally, I’ll do it once and set the knobs out to dry...and do it again if they’re not to my satisfaction.
Works like a champ.
  • 11 months later...
Mine were to the point of being soft like gummy bears so I 3D printed replacements.  Here's the link to the file if anyone wants to print their own.
WWW.THINGIVERSE.COM
If the knobs on your Becker CDR-220 have become sticky this is an inexpensive way to replace them. Mine became so malleable I didn't even want to try any of the remedies that people suggest. Replacements were definitely in order in my case. Factory originals...
  • 2 years later...
Qxyclean Oxygen bleach works great, also used it on gummy dash on 2006 VW bettle  convertible. Could not believe how well it worked.
