Hi All ,
can anyone help with how to remove the inside rear panel to get access to the bulkhead to allow running a wire through to the engine compartment for wiring the remote switch. I've read that you remove the Hex bolt on the seat belt anchor and a screw ?. Where is the screw ?, I found one above at the coat hanger. I cannot loosen the panel enough to disconnect the speaker or pull the panel loose. Please help if you know instructions of how to do this .
Many Thanks
Martin
Martin,
I don't know if the 997.1 is different from the 997.2 on installation in this area but I believe there is a DIY article on this forum for intalling the PSE (as I downloaded it to print) and I think there are instructions on getting to this area. Might check it out.
Thanks Tony, have looked into it a bit more, I've learned quite a bit which was not clear from the info I had. I've managed to remove the panel and complete the cable run, I just need to wire into the fusebox. I will post some pics when I have a minute to help anyone else.
Best Regards
Martin
