I'm getting bit of a high speed shimmy type wobble.
I had the fronts rebalanced but I get this wobble at around 85 90 100 mph areas.
It's like a slight shimmy, nothing drastic but noticeable. I also notice it on hard acceleration.
Any ideas?
Everything stock, recently things I've replaced were tuning fork arms, tie rod ends and drop links.
Tyres are Pzero with good tread.
Possible you could use an alignment? Also, even the slightest bend in your wheel (from hitting a hot-pole) can cause a wobble... but only at certain speed ranges, such as you suggest.
