I believe I broke my driver door inner release cable by pulling too hard on it. I removed the door panel and the cable for the inner handle slides from the tube as it is not attached to the door mechanism. To fix it, do I need to remove the inner door panel? Should I take it to the shop or can I do this myself? Ive read where some people are afraid of alignment issues upon reassembly. Any diagrams that show this assembly? Ive read the TSBs and it has an accurate description but no pictures.
Thanks!!
  • 5 weeks later...
It's pretty involved. I've had to replace the door lock unit on the left rear door. If you can't reach it by removing the interior trim panel, then the inner door frame has to come out. This is the frame that holds the window, lock, and the window frame that goes on the "top" of the door. Realigning isn't too bad but I'll admit it took me about 3 tries to get it lined up where it was so the seals were all in place.
