Parked my 04CTT on a slope for the day. started the car in the hot afternoon and the following problem occurred:
air suspension work shop.
Durametric shows the following code:
143 Damping Adjustment Valve front right
Electrical fault
after deleting the code and drive it around, the same 143 code came back again and with another error:
1437 Control Position not learned
No/incorrect coding/calibration
I checked the actual value:
shock absorber valve current FR 0.000A while the other 3 are around 0.04A while car is parked
the level control seems okay and car drives normal.
does it mean that I have to replace the whole front right shock?
thanks guys
Sorry, my typo... let's try this...
Fault code 0143 -- Damping adjustment valve, front right
Possible cause of fault
- Short circuit to ground or open circuit in the wiring of pin 116 of the level control module (electrical fault in electric circuit)
- Short circuit in pins 116 and 118 of the level control module wires with respect to each other (electrical fault in electric circuit)
- Short circuit to B+ in the wiring of pin 116 of the level control module (electrical fault in electric circuit)
- Short circuit to B+ or open circuit in the wiring of pin 118 of the level control module (electrical fault in electric circuit)
- Short circuit to ground in the wiring of pin 118 of the level control module (electrical fault in electric circuit)
- Damping adjustment valve faulty
- Level control module faulty
Loren thank you for your support.
I took apart the connectors near the lower end of the struct.(there are two connectors, one is acceleration sensor, the other is, I suppose, the struct absorber valve) and cleaned them up. the code was gone, at least for one night. I will see if it comes back, hopefully not, and let you guys know.
Roy
