Got a compressor powered Mityvac. Got fluid, followed directions. Started on right rear then left then front right and finishing at left. I had this vision of really dirty fluid filling the canister from the reservoir and caliper fluid removal. It was darkish. Bleeding the calipers was a bubbly affair, I worked through each wheel and the auxiliary tank drained down as expected. I removed about 40oz as indicated on the Mityvac. Got in car, pumped pedal hard a few times to see what's up, no warning light.....all feels good.
How'd I do?
Sounds like you did everything by the book. Be sure clean up any spilt fluid as it can damage paint and some rubbers/plastics.
