Hi - Is anyone able to tell me the difference between the fuel pump for 996's to 2001 versus 996's from 2002?
Are there any issues using the later fuel pump in an earlier car?
Derek
Pretty sure the 99-01 is a return style while the 02+ is returnless. So not compatable. Looking for 02+ style I have a complete pump. PM me.
If you meant a "pump unit" 987 RDC have it right, you can also remove the pump from the housing and order at Robert Bosch, the identification numbers are stamped on the old pump, it costs a lot less.
