Before my extended warranty runs out I'd like to make sure the alternator cable is not one of the faulty ones.
Was there a TSB on the matter? I have searched but can't find one. If there is one, does anyone know the number? Thanks.
Try TSB 8/06 0101 Breakdowns Due To Loose Ground Strap -- dated Sep 13, 2006.
Jfp-
Thanks but that one discusses the negative cable connection necessary tightness to the body upon delivery
to the customer.
Jfp-
to the customer.
I just realized that you expect to get the new cables under warranty, which you will not unless the dealer does it under goodwill. There is a TSB which tells the dealer that the cables have been updated with a new part number to correct the earlier problems, but it is a TSB, not a recall, so it is informational only. Start a conversation with your service manager, but I'm pretty he may tell you that unless they can confirm an existing problem, they will not replace the cables for free...............
