My vents will work fine ( front defroster, rear defroster, feet and body ) when the key is in the last position right before you turn the car over but once the car is running all my vents stop working ( no air coming out ) along with my rear defroster button not lighting up. Any advice would be appreciated.
mj
Electrical gremlins such as these associated with the key are usually related to a faulty ignition switch. Faulty ignition switch repair is well documented here.
