There is a straight trim panel piece along the back underneath the back window.
Mine got severely water damaged by the guys who detailed the car. I need to remove it and refinish or find a replacement.
Does it just "tug off"? It seems to be attached along the top right at the window. I was just going to yank it, but figured I should ask first.
As I recall when you remove the carpeted/foam piece under the window (that covers the DME) - you get access to the screws (4 I think) that remove the plastic piece.
