I have a 05 CTT, 80K miles.
For the last 6 months I’ve had a front end knock when going over a bump and/or turning the wheel side to side vigorously. I've changed the upper and lower control arm bushing and it made no difference.
I’ve had it up on the lift and I cannot find any play in the wheels. When it knocks I cannot feel though the steering wheel, I can only hear it. It makes no difference what height I set the suspension at.
Anyone have a similar issue?
Cheers, stu
It's often caused by the lower control arm big end bushing but if they are new then I'm not sure, sway bar links/bushings or maybe check the torque on all the subframe bushings.
