Just invested in several Nav-TV modules including the Tooki for my new to me 2005 Cayenne S. To my surprise I have a PCM 2.1 with DVD, but do not have the phone buttons which I understand are required for use of the Tooki. My goal would be to upgrade to a PCM 2.1 with phone buttons and need assistance from others that may have done this previously - despite my searches I have only found one other forum member who claims to have simply swapped the pcm out, reconnected rear connections and all worked fine. Thoughts???
Thanks in advance -
Jeremy
Maybe you could try getting the dealer to code/enable the phone module?
Even though it doesn't exist the tooki should respond as a phone?
Might be tricky to make a call though without the buttons.
Won't cost you much to try the coding, Replacing a PCM is a costly exercise. And requires dealer coding.
My PCM had the phone button but no phone module. I installed a Denison and it works just like the factory module, although you get a phone not found error every time you start the car and the audio is crappy, mobridge is better.
Cheers
DS
