What is the correct drive belt length for the 2008 Cayenne S 4.8 L engine?
Porsche (genuine) and Conti-tech advertise a 2880 mm belt length for $115 plus and all other manufacturers indicate the belt is 2899 mm (114.25 inches) at a much lower price?
Will the aftermarket belts that are 19 mm longer be fine? I see a lot of aftermarket belt usages here on Renntech but no postings for the 4.8 L engines.
Spec on the Porsche OEM is 2880 mm.
The tensioner can likely pick up the difference. Some after market belts are as good as OEM and some are crap - choose wisely.
