I get an annoying clunk from the rear.
It happens when going from reverse to drive, coming to an abrubt stop, going over a pot hole. i've had a good rummage around the back, removed the motor mounts and they were still firm ish, the only bit of slight play I could find was on the rear coffin arm, the bush in the middle had a slight play in it.
But this doesnt explain the knock at a standstill going from reverse to drive?
The most common causes are:
- loose rear swaybar mounts
- bad CV joint on one axle
- badly worn rear control arm(s)
- broken motor mounts
Inspection should rule out some items and/or confirm the issues location.
